Oil pipe on rocker shaft
Lowcommer
Help please, Iv snapped the little union nut on the T piece to the rocker shaft oil pipe.
trying to get head off to replace head gasket and that little nut has stopped everything.
Advice???
Bummer. I think you will need to source a replacement T piece and pipe, be careful though the iron head ones are different to the alloy ones. Speedy Spares of Brighton list the pipe as P48516 ( under Super Minx so I assume it's the same) but not the T piece, always worth an ask though.
Another brass nut connected to the block in the tappet chest, you'll need to take the side cover off to get to it.
