OD gearbox
£60-£100 as a guide these days i think, from auctions I have been watching.
A wandering commer blog - http://commerblog.wordpress.com/
£150 is nearer the mark for a genuine Commer one ;)
i might have a rapier one, i will have a dig about as i want to fit one into mine too - so if these are any good i can probably list 2 or 3 of them for members!
Dave
Would be good, after one myself too. Ideally a car one for the better ratios ( think im right in that aren't I?)
Hasta la supervista baby
The final ratios are all the same 1:1 but be careful when buying an OD box as the later Arrows series ones have a different bell housing , it's longer and makes the gearbox sit over at an angle - makes it awkward to fit.
I WANT CAKE
Final drive is the same on all boxes as it's a straight through connection. There are different ratios on the overdrives, with the highest being 28% on a J type overdrive - if you can find one, but they are usually 25%. As far as I can make out 2nd and 3rd gear ratios are all the same across the range, but the vans have a lower first gear than the cars.
The problem with the arrows cars is that the input shaft is longer than the commer boxes. You can do a mix and match of the box, but it involves dismantling both boxes, as you will need to combine the gears and output shaft from the OD box with the input shaft and bell housing from the commer. Not impossible, and not the most complex thing to do, but you will need a couple if very large spanners (1 1/2" and 1 5/8" from memory).
Hope that helps
A
