more of 1st cvf gathering
Just read this ...Abit late I know ..Overheating ...blocked /gunged up water jacket in block?/Timing too far advanced?/Radiator may look ok ,but has it got blocked tubes?/Thermostat not opening correctly to maximum(even new ones can do this!)/correct head gasket fitted ,not blocking water holes from head to block?/water pump internal vanes slipping on shaft inside the pump?/correct diam. pulley on w/pump ,therefore pump running at correct speed?Cant think of anymore at the moment!
commerchris. I think you may need to check your resolution settings under the display icon in the control pannel and adjust to suit.
Not sure about why AOL is starting automatically because we dont use AOL here. But im guess there is a setting you can have so that it starts when you start your machine. Probably under options menu and needs to be unchecked ;)
Good luck.
cheers 5imon,sorted the restart problem with live help,since then today in fact,made every thing go all tiny on me lol :D:D:D
