The window leaks at the back on the passengers side.
Seems to be between the frame and the body.
My plan is to remove the 3 windows, then remove the white plastic frame
and load it up with bathroom sealant of some description.
The plastic frame may be the hole size so you may have to keep that. Sealant wise, the overpaintable types can discolour (ie sika ebt) so don’t use them.
