Hi all, as some of you already know, i'm in the process of Restoring butchering my van. Whilst i'm no fine fettler, i have however had some success at making myself some semblance of outriggers....[)] problem i'm having though is i need/would love to know the dimensions of the leaf spring hangers. This may not sound clear to anybody but in a nutshell i need to know where to drill the circular piece out in order to weld the tubular tubey thing into it.[B)][)]:I i dont want to go drilling thigs out and welding things in only to find out it does'nt fit properly[xx(]
Where do you want the dimension from? Is your inner rear valance that joins to the chassie ok? If so i will meassure in from there and the top to bottom measurement,if that makes sense?
Thanks for the reply Jon this is the same job as i'm doing right now...http://66.129.69.181/forum/topic.asp?TOPIC_ID=108&whichpage=3 but obviously cannot get the precise measurement from a pic, so if you could measure the distance from where the leaf spring hanger is welded to the chassis leg that would be cool plus from top to bottom. Thanks mate.
Saw this Dic@head the other day, Pis@ed out of his face!!!
