Hi there, Had the van back on the road for a year after a 22 year layup.It's running reasonably well but the temp gauge stays near the red, also any thoughts on hot starting, have rerouted and insulated the fuel line, had the manifold ceramic coated to cut underbonnet temperature, fitted a heat shield, electric fan and expansion tank, even added an extra air scoop below the original (this one goes right back to the rad. All the above have helped but not cured, filled up with BP super unleaded (no Ethanol) last time will see if this helps
