HIGHWAYMAN DIMENSIONS PLEASE
Sorry, but I very much doubt that thecheight of the countryman is 2,7 metres. I''d guess it's more like 2,3 or 2,4 metres high. If you look at the Studiocommer's photo archive I'm pretty sure you'll find a different height.
What regards water leaks, though, I'd say that everything you've heard is true. They usually leak properly. Both mine are affected, but I'm hoping to put it to an end.. !
Originally posted by Panky
Makes a change from welding - a nice bit of timbering:)
Harvey the RV
Cant wait to get to that stage with bluebell lol....Timber work!
Hi BAZ. Built my garage specially for the Highwayman and it JUST gets in under the 2.7mtr door. Clears the skylight by about 2cm. :)
Just thought - what if i get new tyres?[:0]
Aaron
A commer down under - or down under a commer?
Cheers for all the advice guys. Unfortunately I can't put up the car-port until the garage is up as I don't know what garage I'm going to get yet. However, the advice against the tarp' is good. Maybe a small 'local' bit of protection instead then.
If I told you I was a pathological liar, would you believe me? I'M GETTING A HIGHWAYMAN !!!
You've probably got the dimensions already, but here they are anyway.
Caravans International (Motorised) Ltd. list the following measurements for Highwayman for model year 1973 (which ought to be like yours):
Height: 8ft 6in (2,590 metres)
Width: 6ft 7in (2,006 metres)
Length: 15ft 5in (4,699 metres)
