HELP
Due to the looming surgery on Duke, i/we/Scott/duke need
A. a clutch alignment tool
B. an old gearbox to rob the mainshaft from
C. dimensions so i can make one
If anyone has any of the above we can borrow asap.........:)
I've got the gearbox from the PA 1500 - not sure if its any good; it was going to get weighed in soon; speak now!
as this is pretty old though (65) and married to the 1500 lump is it of much use? Also got the 1500 lump but doubt that anyone would ever replace for it!
Tim said the same!but he did say something about cutting something off to use as a clutch alignment tool ! before you scrap it.
Sybhil
that's what I wondered mainly - try and get the spline out?
Perhaps martin can comment (he's had a few of these kicking around in the past but has slightly more space than me!)
I think thats it if its the same as the common vans to use as a tool that can be posted to who ever needs it when they need it.
Sybhil
Originally posted by Panky
I've got an input shaft you can borrow if you need it.
[/ quote Panky can you still get it to us?
Martin needs his tool on fri!
Sybhil
Yes please Panky :p
Jon, if you can cut off the splined input shaft for future use as a clutch tool that would be worthwhile :)
sorry mate - been too busy to check the forum I'm afraid! We're all very good thanks Jessica is up and running again so the kids are all excited about going away soon!
cheers
