Hi Debs,
Has it been a while since you last drove Skye? what happens or doesn't happen when you try and get into gear?
Have done a search through forum and found this reply by Andy Zarse which hopefully might help - just make sure you have enough space to try it in case you shoot forward....good luck....
Don't talk to me about ruddy clutches...
First of all make sure the hydaulics are working. You'll need somebody looking underneath whilst you push the pedal. If the pushrod from the slave cylinder is moving the clutch operating lever back and forth then it's not that.
Stuck clutches are far more fun. Warm up the engine. Stop it. Put it in first and restart the engine so that your Commer starts to move. With your left foot, depress clutch pedal (it's vital the hydraulics are working, as above) and then with right foot stamp on the other two pedals alternately, going on and off the throttle and brakes. The shunting will either free it all up with a bang, or you run out of road. It's normally just a bit of corrosion on the flywheel sticking stuff together. This method does work, my Commer sits in a field all winter and it happens every year.
have sent text to Glyn to see if he has any dodges too so will post if anything else you can try
