porf
0
Hi All,
Took the fuel tank off the Dodge intending to check for snakeskin. I'm assuming this is not an original tank but something someone's had made from steel - so no snakeskin, but some rust..
What's the view of people who've dealt with this sort of thing before:
Can I get away with a damn good clean and put a filter before and after the electric fuel pump OR should I attempt to line it after cleaning?
Only thoughts with some of the tank lining kits is there's more to go wrong and it needs some care to pick one that copes with the increasing amounts of ethanol.
Any recommendations for products, I've seen the following
Clean kit :
Clean and seal kits :
Clean kit :
Fuel Tank Cleaning Kit | Rust Treatment and Removal for Fuel Tanks - Bilt Hamber
If you need to remove corrosion from inside your vehicle fuel tank, our Fuel Tank Cleaning Kit was designed for the task! It contains our multi award-winning Deox-C Rust Remover.
www.bilthamber.com
TANK RENEW KIT
This tank re-new kit is suitable for all petrol, diesel and oil tanks. Contents 1 x 500 ml Rustbuster Tank-Kleen concentrated caustic detergent Industrial strength. 1 x 850 ml Rustbuster Slosh Tank sealer for tank inside. 1 x 1 ltr Rustbuster 2k Tank Guard Hi-build Epoxy coating for tank...
www.rust.co.uk
