I did it that way with a trolley jack, I was cacking myself putting it back as I ended up with the weight of the van on the jack when I was underneath putting the nuts back on:I
I've got no idea what a Churchhill tool looks like, but made this up for the job as my whole front suspension was out of the van at the time. My other problem was that all the bolts that hold the lower spring retaining plates were rusted solid, so I had to remove the top pivot mounts and remove the springs that way.
How refreshing
I'm going to tell on you if you do that again [:0]
I bet Mrs P didn't know what you were doing [B)]
You better ring SSBB next time you need a hand [^]
