Hi I managed to get to the garage this afternoon and get a couple of pix of the front shocks.
The shocks are gas type made by Munro type D8486. You will need to drill out the bottom eyebolt holes to take a larger size bolt. Cant remember the size but i think it was about 12 or 14mm. I just put them in the bench drill and used a stepped bit to enlarge the holes. Worked a treat. The top is a straight swap.
Hope that helps
A commer down under - or down under a commer?
Hope that helps
