Fancy a Set of 16 inch Steel Wheels For Your Van?
Has anyone fitted Jeep Cherokee space savers on a Commer? Fitted with a decent van tyre I think they'd look pretty cool. They should also drop the revs in top gear a bit for those who like to max out their vans
http://www.ebay.co.uk/itm/Space-saver-spare-wheel-/190744819612?pt=UK_CarParts_Acc_Wheels_tyres_Rims_Car_Wheels_ET&fits=Car+Make%3AJeep|Model%3ACherokee&hash=item2c6946f79c
Won't fit as the offset is completely wrong so wont allow you to get the stud area of the wheel flat with the hub/drum.
A commer with even bigger boost will be appering on a screen near you soon!
Oh ok. I just assumed that if jeep Cherokee wheels fitted then the space saver would fit too. Have you tried them? Would they fit with a spacer?
The pcd is the same but the offset of the cherokee is completely wrong you wiould have to fit massive spacers like 45mm up wards to get them to bolt on another problem is the front cone on the hub and the wheel centre bore,its to small;)
Here you go after market 17inch jeep cherokee wheels:
The wheel sitting on the studs but at least a 45mm gap from the mounting face or the wheel hits the leaf springs:
These were only about 7j wide to. Ive now got 9j on the back with no spacers;)
