Exhausting options
sorry studio just thought i would point out that 2" bore is actually too big for the commer,it has still got the 1 5/8 hole at the manifold exit,its the larger bore in the silencer that is making the difference as its less restrictive.
the bigger downpipe will slow down the gas speed causing more pulse reversal at low revs, most people dont realize that exhausts flow in both directions, the mini is a good example as the exhaust port actually flows more in the reverse direction [:0] (take note panky). this causes more exhaust gases to go back into the cylinder to contaminate the incoming charge and raise its temperature which means a drop in low end torque :(.
on my BSA i had 5 stratigically placed dams that prevented gases reversing in the pipe, it was very noticable the way it came on the cam sooner and pulled harder from zero revs.
one 90 degree bend is equivalent to 22 feet of extra pipe,so twisting the pipe everywhere is a no no as well.
i am sure bessie is feeling much better for it though :D
VERY good idea panky [^], should be able to handle over 200 bhp with minimal backpressure, so the rapiers fairly safe :D
Thanks for advice Tim;), low end torque not too much of a problem for Bessie and yes she is a lot happier thank you. System made up of recycled bits we had here and as far as know the downpipe is from Mk2 cavalier which is slightly narrower down to merc silencer at 2"
Once budget allows (and when this system wears out) hoping to do a stainless system with the right spec, but very chuffed with Glyns' efforts and difference is most satisfactory[^] I miss the distinctive commer purr but running cost savings make the meatier bobble liveable[:X]
Ran has a nice burble with the RC 40 [^]but ears have been left ringing on long journeys as the exhaust gasket has gone at the manifold,picked up a new one yesterday 3.20 [:0]just needs fitting now.Apparently this is causing expensive fuel bills.
when i get the chance i am going to look into possibly making stainless systems(free flow obviously) to go on commers,probably side exit using rc40 silencers, i should think they will come out around the £150 mark although thats just an educated guess at the moment. so if anyone is interested then shout :D
