After I gave topped my gearbox I am going to change the oil in my engine. Firstly is the 20/50 oil ok to use in the engine, secondly do I just undo the nut that's under the sump( after putting a container underneath).
20/50 is the one to use and yes the drain plug is the one on the bottom of the sump pan. Run the engine for a while to get it warm before you drop the oil. You should really change the filter as well.
I think the engine takes about 4 1/2 litres, put 4 in then check the dipstick and keep putting more in until it reaches the top mark giving it a couple of minutes between top ups for the oil to reach the sump so you get a true level.
