Well yesterday went pretty well, but we're not out of the woods yet!
Engine in, starter motor connected, clutch slave cylinder connected - didn't seem to work properly, just read Razor7's clutch thread, realised I have made the same mistake and mounted it on the worng side!
Having a bit of trouble getting the fan pulley on the front of the engine. The tolerence is very tight around the hole in the timing chain cover, so I had to remove the cover, and then it fits fine, but when the cover is on and the bolts tightened I can't get it to align. More jiggery pokery today! I think I need to get the pulley on before I tighten the bolts, but then this makes some of the bolts almost impossible to get to - Great design!
Then its just the radiator, alternator, leads and wires to go!
But may actually have a running van by this evening!
