Dash change
Has anyone changed a dash from the later square type to the earlier triangle one? I have both but i much prefer the look of the early type. Apart from the wiring which i will be redoing anyway what else would be involved?
Now with a bundle of joy - and a commer!
The steel work behind the back is all different the cut outs are bigger either side;) can be done though but you would have to do some welding;)
Hi Jon i thought that might be the case. I plan to cover the facia in vinyl so that would cover up the welds no problem. Cheers
