Commer Lowering Jobs... Available now!!!
Alright guys!
Right my summer darkside (VW) rush is over so time for a bit of Rootes action!!!
Commer Lowering Available Now for £425. Drive in... Drive out!
You've seen "Sunny Citrus" and you've seen my gnarly white Autosleeper.
Sunny is out of control! It looks wicked but its undriveable really. I drive it but I'm very tolerant... I build super slammed cars every day and I drive super slammed cars every day... that's my job but in reality it's too slammed!!!
http://i382.photobucket.com/albums/oo270/Bobbymilkandtwo/sunnycitrus002.jpg
The Autosleeper is not quite as slammed but still pushing the limits! I use it regularly; we go to cornwall at least twice a year in it and we take it to loads of VW shows. It's useable but it's on the limit!
http://i216.photobucket.com/albums/cc27/daytona_com/Woolfysmeetcoventry019.jpg
We can lower your commer however much you want... From 1 inch to 8 inches... It's the same job and the same amount of work however you want it...
At the front we cut the springs; I've tried uprated springs, I've tried shorter springs. Ive uprated the shocks, Ive downgraded the shocks. Nothing rides as well as the standard set-up... This in conjunction with lower profile tyres sorts the front.
At the rear we flip the axle so instead of being underneath the leaf springs it rides on top. Flip is probably the wrong word really... The first Commer slam job flipped the axle. i.e turned it upside down. This isnt a good thing to do though because the sump which holds the oil that the diff needs to keep lubricated suddenly isnt there, its on top which aint cool. Our slam jobs keep the axle exactly as it should be... just a bit higher in the chassis. The problem is that by "flipping the axle" it drops the van nearly 6 inches which is too much. To counteract this we extend the rear leaf spring hangers. The front can't be adjusted; it's a fixed mounting but the rear is totally flexible. Remember though whatever you extend it by you only achieve half of that because you're only adjusting one side. It involves pythagoras and a load of other crazy calculations but that's the way it is! I've done them. It was hard work but 4 years studying for a Bachelor of Science degree must come in useful sometime!
If you see a nice original untouched Commer camper it always looks a bit arse down, ie. the back end is lower than the front. You dont really notice it on panel vans but on campers its really obvious! The reason for this is that all campers have sat on their wheels with their camping interior (in effect that's heading towards fully laden) so the weight has been permanently resting on their rear leaf springs which has excessively stretched them. This means that the springs have less tension which in turn makes the back sit lower than standard. To combat and correct this in our slam jobs we have the top 2 leaf springs tig-welded together; the guys who do this for me build the titanium bomb blast guards that surround the British Armies military vehicles... These boys can weld and it won't break! Some people have critised this and said it is excessively modifiying the set-up and could therefore in theory fail an MOT. Theoretically yes that is true but realistically your MOT tester will never spot it. If that worries you, no problem we won't do it. But I guarantee you, drive a commer without and then drive my autosleeper. Its ready and waiting please feel free to come and test it. Lots of people talk the talk but at the Milkandtwo Slam Shop we talk the talk and walk the walk; My personal van is there; if you want to drive it, help yourself, its parked outside my shop and the keys are under the drivers seat...
My main business is lowering VW's with my custom built kits. Thats been my business for 7 years. I drive lowered cars every day. I couldn't even tell you the last time I drove a standard height car!! I've researched and developed this solution for commers by using my own van which I've done 5000 miles a year in for the last 4 years. I stand by what I do. It is the best solution.
If you want to give me a shout call Bobby on 07970 555104
Ive got 2 Commers booked in for this in December but there's room for 2 more in my schedule...
Are you ready?!
Sorry forgot my IMG's!!!
Here's the pics...
I doubt it.
ive had mine done for some time now,and had no issue with mot man,love the way it looks plus the way it handles.luvvit[8D]
Cheers Guys!
As I said please feel free to come and test drive my van. Everyone who has had this conversion has been really pleased with the way their van drives...
The wheels on the white autosleeper are Pontiac GTO wheels. They nearly fit straight on, just a couple of mm out but did look really good. Had a bit of a change now cause they were only on loan from a friend...
Easy Gatt! How you doing?
What year's your new van? Dude they all have the same suspension setup so even though it's such a late model; bring it over and we'll get it slammed like your old bad boy autosleeper!!!
Hey, Just wondering if you can give me some information. I am in Canada and want to lower my commer. To go just a little higher then sunny citrus (about 2 inches higher), does the frame have to get "C" notched and a hole have to get cut in the floor for the pumpkin of the differential to have clearance and not hit the floor of the van?? Any advice would be great. I am in love with sunny citrus and I am on the same boat as you are ----> everything I drive has to be slammed. Any info would be great as I am a great way away from you. haha
Hey Jason. My white Autosleeper is 2 inches higher than Sunny. No c-notching is needed at this height but you may want to uprate the bump stops on the underside of the chassis because you will be using them occassionally! The reason for cutting the floor was to make room for the oil sump underneath the diff when you turned the axle upside down. I dont do this though, I leave the axle as it is but reweld the mounting brackets on the underside of the axle and then put it on top of the leaf springs. No clearance problems at all at the height you want... Dude just checked out your van too. Love it! Im a sucker for an original logo'd van! Good Work! Drop me an email if you need more info and we'll get you slammed out!!!
Gatt I'm worried about your maths... Bluebell was built in 1960, your van was built in 1978... That means bluebell is older!! What years your Passat? Mine's older!!! PMSL!
on this as soon as I've got a van saughted.will give you a ring soon bobby to discuss ride height as I'm used to mental low too ;)
Don't forget that when you cut a coil spring it gets stiffer so don't expect the van to ride same as it did. Also..... don't cut too much off cos if it becomes loose in the keeps when the MOT man has it up on the stands when he lifts the van on the ramp to check the suspension.... he is entitled to fail it as a defective part.
I'm neither for or against cutting springs but find it hard to advocate the idiots that adopt unsafe engineering practices for obvious reasons. Sometimes there are are better alternatives. I dropped my Rapier front (Arrocuda project) by around 90mm by using Sierra lowering springs and a lower profile tyre.
