cold battery
Hi, i am having problems starting my commer. It happens after a few days when i havn`t started it . I will have to use my jump leeds tomorrow to get it started. Any advice?
Is it the battery going flat? Could be a knackered battery or some thing is draining it. Try disconnecting it and then see if it's drained after a few days - if it has it's knackered. Other possibility is that it's not charging, is the ignition light coming on?
Two's company
It seems to be charging OK then, does the battery die off quickly or is it just the engine wont fire up.
Two's company
The first thing I would check is that the earth strap has a decent connection, maybe unbolt it and clean it up. Like Panky said disconnect the battery for a couple of days and see if it still goes flat, if not then with all ancilleries switched off put a tester on them one by one to see if they are srawing a current. I had a similar problem and it turned out that the light bulb in the cigar lighter was staying on all the time and that was enough to drain the battery over a few days:)
As said previously, check all connections and signs of something draining it - other wise new battery I'm afraid:I
Two's company
