Clutch fluid gone
I've just started having a problem with Jess, All the clutch fluid seems to be disappearing! I can't see a leak anywhere, the slave is pretty new (about 3 years) so I'm guessing a new cylinder is required? Is it an easy job?
Martin does a repair kit for very little money, if it's only just started leaking a kit should be OK - I've said that before today:I
Can you see any soggynes if you pull the dust cover back on the master cylinder?
It's a bit awkward getting the return spring off and back on again, and the top securing bolt is a pain (I glued mine in position to make tightening it back up a bit easier;)) - but I've done worse jobs.
How refreshing
I have the same problem except I can see the fluid coming out from the slave cylinder every time the clutch is pressed. the dust cap is knackered so can see the piston coming out with an ooze of fluid. do you think a repair kit could fix this or is it a new cylinder. I have just been topping up every time Ive had a journey :D
I have the fear
