choke wire.
Hi following on from my previous discussion, i have taken my choke cable out to see if it had snapped, but i can`t get the choke wire back into the hole now, it goes about 2 inches and then stops, has anyone got any suggestions.
Hire a mechanic who knows what he's doing [}:)]:D:):D
Moley and Brian the Snail :)
1965 Series IIA Bluebird Highwayman
is the end clean cut?
the wires fine, it gets to where the end of the casing is and stops, its as if thers something in the way now.
could be the edges catching. try twisting the cable as you push it through m8 otherwise there could be something in the casing. could have been the cause of the sticking
problem
But make sure that you are twisting it the right way or it will get even worsequote:
problem
nice one. amazing how irratating the little silly bits can be eh lol
