carb questions
commerchris
0
Hi guys, Question: what carb can be easily fitted to the standard 1725 engine to improve performance, mpg...?
Cheers (this message was posted on behalf of Razor7)
"RAN"the van & N0.1
My Highwayman has an SU on it with K&N filter, it seems to work well and the van pulls okay to. Not sure if I am getting more than 20mpg...I'm guessing that's normal though...if you want I can get the SU model number from it and also the needle type.
If I should be getting more than 20 mpg please let me know how to do it (I am about to fit an elctronic ignition I have to it also).
Ruairidh
you will get more mpg if you replace the standard exhaust with a less restrictive one :)
"you were only supposed to blow the bloody doors off no.3"
Hi Commerracer,
can you knock the baffles through or is there a system available which is less resrictive?
Does it at add much to the MPG???
R
you could just knock the baffles out but it would be noisy ,a good system to use is the RC40 for a mini, its straight through but still silences very well [^]. could add 2-5 mpg :)
is this the beast?
Which part/s should I look into getting, is there much modification needed?
https://www.plminishop.com/view_product.php?product=RC40-KIT
R
thats the fella :), you only need the two silencers really. it needs a little cutting/welding/sleeving to fit but nothing too taxing. it took me an hour to fit one to RAN :p
