Brake Light Switch for 1974 Highwayman..
Great run out in the van today but the brake lights have stopped working, by process of illimination have worked out it is the switch.
Can anyone tell me the part code and/or supplier of these please?
Also, when I replace it is there a way of doing it without having to re-bleed the brakes?
Any advice very welcome.
Ruairidh
I managed to change the switch on the Morris without bleeding. It kind of involved a mini-bleed when I screwed the new switch in i.e. a helper gently pressed the brake as I tightened the switch. I think that worked because the switch was at a high point in the system though...
speedy spares are your friend on this (as ever!) www.speedyspares.co.uk
part # 51600/1801389
Ordered parts yesterday morning and they arrived today before 10am, "Speedy Parts" deliver a service worthy of their name!
Rupert, thanks for the tip about pressure on the pedal whilst changing the switch to avoid re-bleeding, Lillie now has working brake lights again, yipee!
Ruairidh
