Brake inbalance
The van failed the MOT on brake inbalance. I had the drums off today but couldn't see any problem so brushed everything down and replaced with a small adjustment.
Is brake inbalance one of the "features" on the Commmer ?
my van failed on imbalance re; handbrake!
It was adjustment of the secondary cable..
I think Jessica had that, I just readjusted them and tweaked the handbrake cable and it was ok.
"With great cars comes great responsibility"
If you adjust the front brakes by the book, ie just dragging and then back off the adjuster a notch or two in my experience they will almost always pull to one side, a few years ago my MOT tester allowed me to play around with the adjustment whilst the van was on the rolling road in the end I managed to get 'em 100%
Try this, set them as above and roadtest, if the pull towards say the drivers side then slacken off that sides adjuster a couple off notches a road test again, keep going until everything feels ok, up on stands my van has one wheel rubbing slightly the other side is 8 notches off dragging and spins completly free but the brakes work perfectly!
tigger
