Brake hoses
Hello everyone,
I'm trying to get Jessica through her MOT, Martin supplied the required parts in double quick time - thanks Martin!
While I was bleeding the brakes (with the EasyBleed) one of the rubber pipes connecting the master cylinder to the rest of the system split, so now for the question, where can I get 8mm / 5/16" rubber hose from - which is suitable for brake fluid? I could do with a fair bit as most of the pipes look a little tatty!
thanks
any hydraulic hose specialist should be able to help with that. i use parker stores in aldridge its part of the james lister group so there are similair places dotted about all over.
The steel pipe rotted through on Harvey so I replaced the whole run with a lenghth of hydraulic hose from a local supplier (Power Hose Systems), 1 metre was just about right and cost less than a fiver:)
Summer's here.....
Told you
