its 6061 marine grade aluminium copied from the water tank with a little extra depth and length ,the cut outs are for the chassis outriggers.
should hold enough fuel for those long range missions deep into darkside territory, berlin and back unescorted
"you were only supposed to blow the bloody doors off no.3"
I know you have probably built in a solution but wont the cut-outs cause an air lock stopping the petrol to fill right to the top of the high points :I.
hi woolfy , glad you like it. it has a small pipe that links the chambers so it should fill to about an inch from the top [8D] it leaves a bit of breathing space and i dont trust the sender seal
100 0/0.
did you see i am getting the sliding door van
it could have been much better if the welder had not played up half way through and if i had an assistant to help tack it up, its not easy trying to hold a torch a rod and hold two pieces together at the same time [:0]
