Anyone good with motorbikes?
does it rub on the tyre to make the lights work?:I
i dont know i cant see from here[B)]:p:D
i don't even know if it has one mate...it wouldnt stop it starting though....if it wasn't working it would make the battery flat but it has a kick start aswell as electric:)
kick start
Used to like watching that .........[8D]
Spare a Commer Guv?
Me too...as a teenager my mate had a couple of trials bikes and we used to always be out on them trying to copy things we saw in the show[8D]
After a while of trying it petrol starts pouring out the overflow?
Float needle is not seating, so it,s flooding :)
What bit is actually the 'float needle ' Tim ? I take it apart and I know what the float is, just not sure what the 'float needle' is:I
the throttle cable is attached to a needle with a spring on it and this appears to be operating properly...there is also another needle on a spring that should operate electically as it has 2 wires attached...
Take the float bowl off, and you will see the float, which pivots on a pin, part of the float pushes on the needle so as the fuel level drops down the float goes with it and allows the needle to come off it,s seat allowing more fuel in. Sometimes a bit of crud or rust gets in the fuel line and stuck on the seat of the needle so it can,t shut off and the carb floods. take it all out and give it a really good clean :)
Thankyou for your help Tim, I will go and take it apart again tommorrow and let you know how I get on:)
And would that be enough to make it not start? or do you have any other theories about that?
I have a new spark plug and the old one and both seem to be sparking ok which if I'm right would signify that the condensor and coill are working ok?
Looks like this.
Fantastic:D Thankyou Tim, it all makes sense now![8D]
took it all aprt again today and following Tim's advice it does not leak petrol everywhere now but it still won't start. I have given up now as its booked for an MOT Wednesday so the scooter shop can sort it out tommorrow. technically we have sold it anyway so any repair will have to be knocked off the price for it...
Thanks guys for trying to help anyways[8D]
well for anyone interested it turns out the plug lead had corroded causing a short that had knocked the immobiliser for six! peugeot want £280 for a new one[:0][:0] so they are going to fit a new non peugeot one for less than half of that:)
thats exactly what i told you it was colin[}:)]:D
is a dynamo the same thing then Mark?:D
very similar i think:I
