Another diff question
So does anyone know how i can work out the ratio of a diff?
I have four diffs and they are all out of the axles. As far as i can see through the grime they look about the same. How can i work out which ratios they are? Do i just count the crown and pinion teeth and divide it out? It would seem a bit too simple if it was that easy[B)][?]
The ICEMAN is alive!!! - just needs a change of fur....
As far as I know counting teeth is indeed the way to go.
Spare a Commer Guv?
There should be a stamping on the diff case. Failing that turn the input shaft and count how many turns it takes for the road wheel to do one full revolotion.
Summer's here.....
So they say
