A sad end to Dora's exploring
:( Yesterday our two week camping trip in Dora came to an end on the M4 outside Cardiff. As I pulled on to the M4 at Swansea as I changed up to fourth gear i heard a clincking noise and some thing sounded as if it hit the bottom of the van.
As we whent further up the motorway another clinking noise was heard so I pulled of at the service area only to find that I could not get any gears [:0]. On investigation I found that the clutch selector arm in the gearbox has become detached inside the bell housing
Today I will be striping out the gearbox (rain permiting)to find out what the problem is.
Sunbeam Sam I will contact you about the wheels do to breakdown unable to collect them.
Oh dear! lets hope you can get her sorted with minimal effort and expense.
How long did it take to get home on the truck?
I do hope the rest of the exploration was glorious!
We did have a good explore in Dora. After a False start - where we had to turn around and come home after the alternater went. This was replaced and we set out again the next day - only to run out of gas (LPG) on a Bridge on a very busy road(with no hard shoulder) over the Llangollen canal. Jim FIXED IT after an hour and a bit and after refuelling we got to the first stop Bridgenorth
She then went great on the gas.
We got to Hay on WYe after a stop off at Halfords- Kiddiminster for some new spark plugs
Then on to Llandovery
Then to Tenby and wiseman's bridge
We the went on to Goweton- it was on leaving Gowerton on route for Cardiff that things went wrong.
miamac
I striped the gearbox out and found that the bolts holding the thrust bearing arm had come out :(. Now back in with locktight :D checked the clutch out still plenty of life so bolted it all back up. I will put the exhaust back on and road test tomorrow (Hopefully a couple of days away in the lakes
Admin three and a half hours on the tow truck 250 miles we had to wait 1 hour 30 for the tow truck (they had to fetch a driver in due to tacho rules and the distance we had to go
Dora and Gloria
Crikey O' Riley how frustrating is that [V], still a simple fault easily fixed - not bad for a van that was destined for the scrappies a few weeks ago. Good job [^]
sorry to hear the great welsh adventure ended early[V] - good luck with repairs
Great to see pics of where you got to before the piggy back home - I know Tenby & Wisemans Bridge, and have met the sculptor of that gert great statue in Llandovery - bit spooky innit[|)]
Hope you get back out there soon, good luck:)
a nice easy repair [^] although a bit of an odd thing to happen [xx(]
