1972 Commer PB Highwayman Parts Manual and Service
Hi again, what parts manuals and service manuals relate to the 1972 Commer PB Highwayman, looking to buy hard copies for referencing, if it help the ignition key is stamped Roots.
Thanks
Joe
This link will take you to the download links on the Forum homepage, you should find what you need on there and print off what you need.
Thanks again John, will try and find the right one, its the Roots then Chrysler bit I guess is confusing unless they are the same essentially.
It will mostly be the same as long as the van isn't a Dodge badged one with the plastic grin, even then it's only trim.
