Slowly ticking jobs off the to do list.
I've bled the brakes but found a damaged thread in a wheel cylinder so Ive got a new one to fit.
The servo vac pipe is on now.
I've fitted the oil pressure gauge into the voltmeter hole in the dash. The hose turned out to be too short but.... I had a spare braided brake hose which screwed into the block! I needed an adaptor for the other end though. Had to knock up a bracket to hold it.
I've also wired in the front fogs using a relay and a NOS foglight switch.
