jimberlake
Noooooooo - Nicole Kidman will be upset
Is that to repair your overalls... Are you writing "YouTube Star" on the back of them?It's ok because I just bought a vinyl cutter...
I wouldn't say star. LolIs that to repair your overalls... Are you writing "YouTube Star" on the back of them?
Asap. It only has to hold 25% of the vehicle weight. The effort at the drums is double the actuator force due to the arm lengths so it should get 30kg at each wheelwoohoo! when do you think you will be able to test it on a hill?
The shoes are adjusted up so movement is minimal on the rods atm. I will knock a shoe out of adjustment for the next vid to show how the compensator works.Looks lovely under there Paul, I don't get it though, are those steel arms pulling it on and off - clearly it's working but they don't seem to move any distance or is that enough? Also what's the thing behind that spins on the diff on the last pull at 12 secs?
