PaulJL
0
Yeah, or a limited slip diff..And you need some sticky rubber on the back
Erm.. let's just say a motorway policeman would not be happy about the speed achievedAny confessions to the top speed reached on said "bumble"... You deserve all the fun after the hours of work and waiting... Well done.
It's actually pretty stable under power. Bit bouncy on rough roads though, the coilovers are rock solidThe back end must be pretty lively, hardly any weight there and all that power and torque on tap must make it interesting
There's still a fair bit of weight to go in yet. Will be fineIt should be very controlled on a smooth road. Sounds like the springs are too hard, i can't remember what poundage they were, but it should be written on them.
You know what... it might have done.Is it touching the baffles in the tank?
You will need to make sure that leaving the door ajar does suck air out and not draw air in. When I have driven a car with the tailgate ajar it has sucked exhaust fumes in. However, the position of your exhaust pipes may prevent this.Tank sorted and refitted. Devised a way of having one of the back doors ajar when driving to suck some heat out.
Just started cleaning the inside now... yeah, I know I've changed lol
Good point but the front windows will be open or I will use the Swamp cooler.You will need to make sure that leaving the door ajar does suck air out and not draw air in. When I have driven a car with the tailgate ajar it has sucked exhaust fumes in. However, the position of your exhaust pipes may prevent this.
