Rocker shaft
Neil T
Hello everyone, is there a torque setting for the eight rocker shaft bolts ?, there’s very little info in the book !, thanks neil.
I can't find one either, it's not in the Commer manual or Hunter one I've got. Just good and tight but not banjo spring tight.
Neil T
Hello everyone, I’ve just found this info on the web answering a question I asked a couple of weeks ago on our forum regarding the torque setting for the rocker shaft bolts. Hopefully will help someone. neil. D1829D77-F431-4B9F-AEEB-6DBEAA24D686.jpeg
Neil T
Hello everyone, got the rocker shafts stripped cleaned and reassembled only needed 4 new adjusters so pleased with that. Cleaned all around top of the head then checked all the tappets for wear which were all good !, it should all be ok really only done 43 thousand !, neil 94D3A566-9DD5-4E7C-9A40-843148987C34.jpeg
