Rear diff gasket
Discussion in 'Mechanical Hints/Tips' started by jimberlake, Jan 6, 2018.
  1. jimberlake
    jimberlake Well-Known Member
    hi all. I’m going stop a couple of diff leaks one from the pinion and one from the rear plate. Does the rear plate need a gasket or should I be ok with good gasket sealant?
    Ta
    Jim
  2. colinthefox
    colinthefox Active Member
    Jim, if you're replacing the diff pinion seal, be aware that the correct size is 1.625 (41.275mm)shaft, 2.75 (69.85mm) housing, and .5 (12.5mm) thickness. These are no longer available I think, so the next best standard size is 1.625shaft, 2.75housing and .375thickness. Shaft and housing are exact, the difference in thickness doesn't matter, and in fact gives you more choice of fitting position to avoid the wear groove.
    I mention this because I have had the wrong sized ones sold as replacements from two different suppliers before, and in the end got one to size from a bearing supplier. I mentioned it to Martin and he was going to look into it.
    Nut needs to be TIGHT, and I've Loctited mine for good measure!
  3. jimberlake
    Thanks Colin, I have one from Martin and will check those sizes tonight. As you said the thickness shouldn’t matter hopefully. Was planning on marking the nut position and numbers of turns off so could torque it correctly. Will the seal width affect that? Will use the lock right plan too thanks.
    Heard to also use gasket seal around the outside of the pinion oil seal also to help stop leaks
  4. colinthefox
    Best of luck trying to torque it up under the van. The problem here (apart from being under the van) is that the half shafts have a lot of flex. See the last post in my Jennings Restoration thread for a method of getting the nut off and tightening it back up without winding the van along the garage (or worse, off the ramps!:eek:). The seal makes no difference to this. Shouldn't need any sealing round the outside, apart from lubrication, as it is rubber and should seal OK as long as it's the correct size.
  5. jimberlake
    Can’t wait now Colin :) one of my problems is that it’s on axle stands. Need to get the wheels on ramps and the front handbrake on hoping that should do it...or just leave it leaking a bit
    Will check the Jenning one out now
  6. jimberlake
    Read...genius and a big help Colin have bookmarked the page ready. I might even get away with no rapped knuckles with that method :)
Share This Page
