Thank u panky , I searched most of my posts looking for some pictures all but that post,pictures are great ,hopefully be on the road this weekendHere you go. I remembered a bit of a thread hi-jack![]()
Thanks panky , got the cylinders in and all put back together , will hopefully have it bled tommorrow , bit of a nightmare getting it all together but got there in the end , I could definitely do it quicker next time , anyway it's all a learning experience . Hopefully bleed it tommorrow. Thanks againYes they all need doing. Probably best bleed the front first to get rid of most of the air then the sequence is, looking from the back, rear left hand side, rear right hand side, front left then front right. You may need to do it a couple of times to get all the air out of the system so make sure you have plenty of fluid to hand.
