Thanks Panky for those tips. I might re route the fuel line.Excellent well done looks great
One little thing I would like to see changed is the fuel filter moved to before the fuel pump as low down as you can get it in the cooler air. It will get hot where it is and cause fuel vapourisation, also a good idea to rout the fuel line from the pump to the carb in front of the radiator for the same reason.
Probably the best place for it for filtering, make sure you put a nice big one in there. The only problem being it would be awkward to have to change it with a full tank of petrol.
