SHAUNE
Afternoon all
I have just fitted a new cylindr head gasket, followed all the advicegiven, thoroughly cleaned every part and surface.
labelled all parts and fitted them back in the same place they came from.
Started the engine and no issues it started sounds fine, let it walm up and bed in but when I went to drive it was really gut less.
Did a compression test (foolishly did not do one before I removed the head) and the first 3 cylinders were 75 psi the fourth 66psi.
Having looked at the hand book they should be 125psi.
This is were my limited knowledge runs out.
Any body any ideas what I need to do before I take it all to bits again
(Cylinder head torque down to specified setting)
Thanks
Shaune
Thanks
Shaune
