Head Skimming / Unleaded valve seat conversion
Hi all,
What is considered as a normal amount to skim from a Commer head to improve torque and drivability? And who has had Unleaded valve seats fitted? Do you think it was worth the expense over lead replacement 'jungle juice' ?
Lastly can anyone recommend any particular firm to do this (south Central UK)
Regards
Mike O
Tim would say skim it to death after gas flowing;)
I've stopped using additive after advice from people who have been running classics for years without issue just using straight petrol. Unless you are doing mega mileage or towing a caravan then I wouldn't bother, if it gets to the point where you're running out of adjustment on the valve rockers maybe consider getting them done then - many years down the line.
martin maltas
Moderator
I have never done the seats on any of mine and would only recommend it if the old ones have burnt out. As Panky, I don't use additive either. Tim's the man for advice on skimming, I think he said 20thou.
Leanne
Hi martin,
Did you get your cab carpets yet
Cheers David
daytona
I had 60 thou taken off mine some years ago and it made a big difference to power and torque coupled with the HIF44 SU carb conversion.
Tim said to me afterwards that you could probably take 1 mm off without any problem.
60 thou is 1.5 mm, just goes to show how much you can get away with. But don't go mad as the bottom end comes under a lot more strain.
Leanne
So you don't use the additive, I've always put the lead replacement in on a fill and its a messy job most of it ends up on your hands. I'd prefer not to use it
It's a personal choice but for the mileage I do it's just not a problem
Retro Andy
Like the idea of skimming the head to increase compression. Porting the head works well too as does a decent manifold.
Have been running Redex, but buy mine at car auto jumbles where they are only £6 a container as apposed to Halfords £15 plus. Not sure I will bother now though
Retro Andy and The Artful Dodger
SU carb conversion and tubular manifolds is the way to go - the difference has to be felt to be believed
Retro Andy
That's my route along with a ported head which I will do my self and post some shots when I do and when I get my blurry lens on my iPad fixed! Will need to know details of where I may find the carb conversion.
Signing off but will need advice on engine soon.
Regards
P.S. What's Face Book?
