Fuel cutting out
Pat cabs
Rerouted fuel line across fan cowling too carb from pump, running great until I'm in slow traffic, then it's cutting out. Having to restart, any ideas please?
Could be running a little lean. Try turning the mixture scree out a quarter turn
Pat cabs
Did that panky, cheers, running smoother, the pump is pumping well, but sometimes the fuel is very slow going into the online filter, which in my opinion is a little bit large, could that be an issue, checked fuel line, no leaks
It could be that the filter is acting as a heat sink and getting vapor locked. Try it on the inlet to the pump as low down as possible and yes try a smaller one too.
Pat cabs
The way it is just now the online filter is on the line coming out of the pump panky
