brake drum forge
PaulJL
always fancied a small forge, somebody mentioned using a brake drum so I raided the scrap bin, got a wheel, 2 hubs and a drum.... Just need a tool rest and an airbed pump now... And a bag of coke
PaulJL
its all nailed together now. Airline connector on for air supply through a restrictor, just needs testing now
PaulJL
picking up 50kg of coke tomorrow so I can have a play. I'm assuming for £20 its not the class A drug
You'll soon find out when you fire it up, the whole neighborhood will be flying if it is:eek:
PaulJL
Decided to make the burn area larger by cutting a bigger drum to sit ontop on the other. This will double the depth and widen it by a few inches.
PaulJL
Oooh. It works! Need to increase airflow though, the compressor couldn't keep up and the electric airbed pump managed... Just.
PaulJL
It works!
PaulJL
Went into the local charity shop to buy an old hair dryer but they had a 240v high output airbed pump for a fiver.... Soon see if its man enough :)
