Blazing Burners.
PaulJL
Started to get some paint on the Foden. Shame really as it hides a lot of the details
PaulJL
I need to cut an accurate...ish circle out of some 2mm steel plate. I have seen pictures of an adjustable compass/guide for a plasma cutter. I'm a tight arse and £30 is a bit steep... I raided my scrap bin...
bazzateer
Sometimes used for cutting holes in sculls, not with a plasma cutter though :eek:
Cutting a hole in a scull would negate the purpose of a scull wouldn't it?
Definition of scull
1a: an oar used at the stern of a boat to propel it forward
1b: either of a pair of oars usually less than 10 feet (3 meters) in length and operated by one person
PaulJL
It definitely works :) the big one has been used as a damper to get more heat into the heat exchanger. Had a play directing the heat into the garage too. Dont want to freeze in there over winter.
