Would this be the right wiring for the regulator.
Positive / A live feed coming from ignition switch. Negative/ A wire run to earth / chassis. F / A feed run to the fuel gauge, then from the gauge to the petrol tank sender.
Are you looking to fit a voltage stabiliser so the feed to the instruments is a constant 10 volts? The item pictured is an alternator control box so I'm not sure it will do the same job.
Thank you Mr P, it is a voltage stabilizer that I require to feed the instruments, could help me by telling me what I require, I have had to rewire the Ambulance and I am more mechanical than electrical
Find many great new & used options and get the best deals for Instrument Voltage Stabilizer / Stabiliser / Regulator (solid state) -597- at the best online prices at eBay! Free delivery for many products.
It connects directly to the original wiring of many cars including MGB/C, Midget, Spitfire and many more. Adaptor leads are provided for other applications. The CCVS1 stabilizer is designed for. The original and the best!
I have replaced with original type and then the little electronic one. I have also used a 9v battery when I was waiting for a replacement to check the fuel going on holiday.
